which tailgate lock to buy
06 2500 4X4,HD with the expansion joint fwy blues!
Bored with truck....Now What????
There are two brands that my dealer said he could order for my 06 Ram. One is made by Bully the other Pop in Lock. Bully is $6 cheaper. I know nothing of either type. What is your suggestion.
I just installed a Bully lock in my 96 two days ago. Seems to be OK. It stops the rods attached to the handle from moveing enough to unlatch the tailgate. I looks like it would be not too hard to defeat - the plastic trim shield snaps in exposing the internals of the handle, rods and lock. If I ever get around to it, I'd like to move the handle to the inside of the tailgate and weld the hole over with a patch. I got mine from E-bay for $25. 00 shipping included.
You don't say if salt roads are a problem - - - my bully gave up last winter - - couldn't get key in even when I kept it lubed - - - replaced with a pop-n-lock and it seems to be OK so far.
Denny
I've had the electric pop-n-lock for 3 or 4 years and it works great. But as with the Bully, apparenlty, pop off the plastic trim and you can unlock the handle with a screwdriver (to move the mechanism).
-Jay
Bretram65 - - - It wasn't the assembly I had a problem with - - - it was the lock it self that I couldn't keep lubed.
Denny
Power Lock
I installed the Pop-n-Lock, Power tailgate lock and it seems to do the job. Had one on my 98' and at times had issues with it sticking, just a little WD-40 and it was okay. The newer model seems to be built a better. The design is different. The install was easy and operates much easier than the older one. Highly recommend it.
I have the manual pop-lock. Fairly easy to install, no tools. Fairly easy to defeat, as mentioned above, but the tailgate "looks" locked, which is usually more than half the battle. I also welded extentions on the locking arms of the two shell/topper swing-up rear hatch locks, so the locking arms extend about 1" past the shell frame on each side.
