Which TST program with injectors?
Smarty downloads
Micrlon?
JStieger
For the guys that run aftermarket injectors and a TST PMCR:
I've been running the TST 03 early twins program for a while now and I am kind of leary to try any other because when I had the standard TST it was a virtual code monster.
What programs have you've been running with injectors?
I'm thinking that I may need to go easier on the TST programs with injectors to get more "fine adjustment" back??? - Especially when you combine injectors with a TST that's "all in" at low boost psi... then add the low fuel special Smarty on top of that!
Thoughts?
When I'm playing around with the truck I run 6-6. But I don't have twins or the twin program. Normal driving I keep it on 4-4.
I have been considering the BD twins.
With my stack bullydog DL on lowest setting, Edge on level 2, TST on 3/2. . I just feels right... . I have it on standard program... After moving the ground from the battery teminal to the dash I have had no code issues...
