which turbo for me
Excessive Gray Smoke
Cleaning my Engine
I will be adding 50 hp nozzles in the near future. I tow without my box off. My box is probably turned off 80% of the time. I tow loads as heavy as 30,000 lbs+ gross weight and I tow 16-24,000 lbs gross almost on a daily basis and sometimes for extremely long periods. What turbo would be best for towing with injectors only, but would also give me the ability to run my Quad race module on 130 w/ the injector nozzles.
I am not after any particular brand - just a turbo that will perform as needed. There may not even be a turbo available to suit my range of needs.
Many have used the 62 class turbos and I have heard the 66 class is fine for towing with manual trans. If you are really looking for low egt balanced with driveabiliy twins seem to be the way to go.
