Which turbo for me?
Another clutch thread
91 ctd axles 4x4
Dan, You've riden in my truck. Huge drop in egt's, more power, beter spoolup and way more room to grow. Brady was talking about basicaly the same turbo I have. s300 62/65mm with a 12cm (. 80 a/r) housing with duel wastegates. Besides KTA said he could get basically that turbo for a good price. For reference my 96 makes about 20 to 30 less horspower with 550 more degrees on the pyro with the hx35. I wish either you or Micheal whould get one of these so you can help convinse the working first gen guys to up grade. On the power master turbo I would really like to hear some feed back on that thing but I think that is to big for what you want.
Good Luck,
Cade
I just did all the upgrading I'm going to get to do for quite some time, Cade. * I just installed a Super 40, with a 16 gated housing, HTT manifold and 4" exhaust. * I've only put about 8 miles on the setup so far, but boost is up from about 28 to 34, and pyro is down. * I'll report more, as the truck will be tied to a trailer ALOT this spring. * Spool up is better then my stock charger. * I need to do some more driving and figure out what else. * I don't think power changed much, but I see at least a 300* drop on full throttle blasts. * We'll have to wait and see if my surge went away, stayed, or got worse. Michael
just a quick question, how much max boost can be expected from a stock H1C? so far ive hit 21psi, and i have a feeling that if i could find a big enough hill i could get 25psi+
HTML:
DUH... . I think Va has plenty of hills. Those are the things in the background that look sort of like mountains... kind of up against the sky.
Tugger... send him a pic of a hill will ya???
Shheeesh... some people:-laf:-laf
You can also turn a few screws and get 25psi+. Mine with the 60mm/6blade impellar makes in the mid 30s in 5th gear.
DP
yea i have yet to even touch my injector pump. i have a 366 sitting on my desk waiting to be installed, and ive never turned up the fuel or adjusted the diaphram, so i think its not too bad that i can get over 20psi with what i have (asa, 4inch dp)
Jleonard - hahhha yea i live about 20-25 minutes from WVA an i work about 5 minutes from the the border, so we do have hills around here trust me. i just havent gone to the big ones yet since i did my latest exhaust and intake work. Oh we got some hills round here let me tell ya... . we got some hills :D
