Engine/Transmission (1998.5 - 2002) Which Turbo
Engine/Transmission (1998.5 - 2002) High boost ?'s
I am @ 100K miles, time for Jammer 5'S-Drag Comp or Smarty?-Snow water/Meth and an HTB2 /62 or 64? I tow occasionally 15,000 CVWR.
Looking for experience and . 02 worth. Thanks in advance. :eek: :)
Edge Comp, F1 mach 4s, HTT Htb2 62/12cm Great power turn the box down and tow. Turn it up and go you should be in 500hp range. Pay the extra money for the F1 injectors!
The F1's are all built and tested by one guy, who tests different spray angles and etc. to get good power and keep egts as low as possible. I will be going to these soon, but the jammers are very cheap, so they will work for now. . What OPoole said for a set up will work very good, basically what i have with a little different brands, but i can pull anything and not have heat problems until your running on the higher box settings. . Great set up!!
kswieringa said:
What kind of pumps or big line kits are needed to supply expected HP?
I would highly recommend the RASP, but I'm a little prejudiced. FASS, various pusher pumps, Vulcan big line kit, etc. there are many options. Either way, just make sure that what you eventually decide to do supports the lift pump as well as giving you bigger fuel lines as the lift pump is going to be the weak link. Like I said, if you can afford it, the RASP gets my vote if you're looking to eliminate and help prevent fuel pressure problems and lift pump failures.
I like the 62/12 that I have with my setup, but a 62/14 would be a great setup too. I went with the 12 cause I wanted to be able to spool as fast as possible between shifts. I towed the other day and it climbs to 1200 pretty quick, but never got past it. Since your going to be towing 15K I would recommend the 62/14 or the 64/14. Probably the 64/14 would be my first choice. I new I was not going any higher on the HP on my 01 since I have the 97 to play with so I couldn't beat the price on the 62/12. PM me if you have any questions. I can probably get you a sweet deal on one.
