Which type of anti-freeze to use?
Likes the look of the spare tire rim w/315's
Scary Larry
After a water pump install, I am a little low on coolant. Would it be better to use the generic, "mix with any anti-freeze, in any vehicle" type of anti-freeze. Or is Dex-Cool okay? It's the only red stuff I can find short of going to the dealer and paying an arm and a leg for the Mopar stuff. Thanks!
I would recommend that you find a Cummins dealer and buy yourself a gallon or two there. That way there is no question you are using the right stuff.
Dex Cool is what you want.
I disagree, jwilliams. The factory fill is HOAT, NOT Dexcool. If you need to add to the factory fill, use Zerex G-05.
Personally, I wouldn't let Dexcool in my garage, let alone in my vehicle. It has a nasty habit of turning into jelly, especially if mixed with another coolant that isn't compatible.
I'm running Fleetguard Compleat PG. 3 years, roughly 50k miles so far.
Ryan
i ran dexcool in my first gen and when i sold it at 275k the radiator looked like new ...
i've had it in the '01 for 50k ... and at 140k it looks perfect inside ...
'course i run it with distilled water also ... after flushing out the old
have you had any bad experiences with dexcool yourself ?
The most important thing is to stay consistant with what you run. If you change types do a very good flush. I have seen some nasty gelling when some types are mixed.
Bob
The Dexcool is a OAT fluid the one DCX uses is a HOAT fluid.
I have used Dexcool in my 99 and 04. 5 with absolutely no issues. If I do find some I will report them though.
Bob
I've heard about coolant gelling and I sure as heck don't need any of that mess! I have three different types of anti-freeze sitting around but I don't think any of them are the right one. When the weather gets better I will probably flush and refill with normal anti-freeze, but for now I just need to top it off. I will have to look around some more and try to find some Zerex or Fleetguard. The service manual does a pretty good job of only reccomending Mopar fluids, so no help there. I guess it would have been to simple for them to just use the green stuff like others have been doing for decades. Change is'nt always good!
I use the Fleetguard complete... have been for the last 5 yrs on two trucks. Works great! I also agree that if you change coolants you need to flush the entire system very well.
You can find Zerez G-05 at Napa. About $11 a gallon.
Good ol' Prestone in my rigs. I do add some RMI-25 each time I service a vehicle also. So far, 175 k on the '03 and radiator is spotless inside. :cool:
