I have a 2004½ CTD on order-I have been reading about EGT's, lift pump failures, etc. I intend to keep the truck mostly stock. I intend to pull a 10K camper in the mountains a lot. Manual, so trans temp not necessary. I figure I need the following three guages.
1. Fuel Pressure-with senders before and after FW separator, and toggle switch to switch between senders.
2. Boost- should I get 0-30 or 0-60-remember mostly stock truck.
3. EGT-pre or post turbo... or both with toggle switch like fuel pressure.
Don't know for sure when I will get truck-dealer thinks he will be able to get VON on or about 12/10. . delivery probably in Mid to late February.
