Which VB to fix shift shuffle?
Engine Light Came On
transmission rebuild?
Ok I'm almost to the point of buying a VB or shift kit to get rid of the 1-2-1-2 or more like the lite throttle 2-3-2-3-2-3 shuffle.
Wich one are you guys using to fix this problem?
Oh yeah my truck is a 2005.
Did you have the TSB done , it seemed to help mine. I think any of the aftermarket VB's will get rid of that problem.
Yes I did but it seems to have made it shift smoother, not as crisp so to speak, not what I was gunning for.
I'm so tired of the shifting problems with this transmission, you know one would think that seeing how this has been a problem almost from day one they would try just about anything to remedy the problem.
In simple terms in 2004. 5 they got rid of the the throttle valve cable and came out with a electronic actuator. All the enhancer does is gives the adjustability to the computer as if it had a cable. Every truck is different stock modified so we can tailor it to your trans as we do with the cable. The one we use is by DTT and is fully adjustable by a dealer and it has three settings for the end user. Any more questions give me a call here anytime 1-800-477-6127
You could also fix it with a shift enhancer box a bit cheaper then a vb
Not neccessarily. The shift enhancer will fix these problems some times but not all the time.
Frequently it will take the shift enhancer and a shift kit or VB to solve all the problems.
