which vw's come with ve injector pumps?
1996 Chrysler Town and Country Question
Subaru Motor
since they are so easy to hot rod:) and rebuild does anyone know which years of vw diesels came with ve pumps, seems like it might be a fun little car to hot rod. :D
Check out this site it is like TDR but for VW diesels. Extremely informative and lots more indepth technical info there than here even. I have an 03 jetta tdi and go there a lot for info.
www.tdiclub.com
The 81 I had was VE pumped.
The 99. 5 I have is VE pumped.
I think all the older ones from 78 thru at least 99. 5 have VE pumps.
There is one Mod that is electronic. If you to the TDI page, search on Champaign performance on a beer budget.
I did it on my 98, It was adding a diode across 2 wires in the harness that goes to the pump. good "seat of the pants" increese.
Jay: Your '99. 5 has a VP-37
It's a resistor, not a diode. I used a 660(?) ohm fixed value resistor wired up with a switch mounted on the dash of my TDI. With the switch 'on' and the resistor in the circuit, she stumbles at idle - that's your clue. Most people use a 1k ohm variable resistor so they can dial in the point where it stops stumbling at idle and leave it there. Since mine is on a switch, I shut it off when I don't want to deal with the stumbling... and turn it on when I need the extra ~15hp.
With the resistor in there, you're messing with the injection pump feedback to the ECM - effectively lying to the ECM and telling it that it needs to command the injection pump for more fuel. :cool: Depending on which method you use (fixed resistor, variable resistor, toggle switch, etc. ), you'd be hard pressed to spend $5. 00 to do this mod
IIRC, you wire the resistor across pins 2 and 3 in the injection pump harness. Double check to be sure! Do it on the 'car' side, not the pump side - for obvious reasons.
www.vwdiesel.net is another great site
Cheers,
Matt
