ok I cant find a Red wire on the lift pump..... I found the hot wire tho... . Need to get a relay and a Fitting I messed up... . But running the holley blue, thru the LP, I was getting 11psi cold. then I found the leaking fitting I screwed up so the gauge is unhooked... I'm going to pick up more hose, a fitting and a relay... so hopfully after my apartment hunting I'm leaving for now, I'll have to truck 100% done!
Thanks guys!
Rick
