White Nights
Dump-Beds & Hitches???
Who's got White Nights from Genos?
I took the white nights and band sawed them down the middle , welded some angle on the ends of the hitch bar . It finishes off the hitch bar nicely and no moving the connector and dealing with the pin. It also gives you a better pattern of light. I got the ones that were not punched out in the middle. You have to extend the wires to the width of the bar.
Great Idea! I mounted mine as per installation inst. except I moved the switch up front to the lower right knee panel so I could turn the lights on or off from inside. I can leave the truck running in neutral with the lights on. They sure make a difference when hooking up to pull someone out that is stuck, hooking up a trailer or closing a gate.
Ron
