Folks, truck ran fine up until a few weeks ago. Lift pump in my 04. 5 had been converted to the in-tank setup and died, no fuel in the filter. Installed a FASS platinum 150gph, cleaned out tank, installed FASS Suction tube kit. Truck started and seemed to run OK, I had an AFE stage 2 that I had ordered and was anxious to install while I was off, when I completed that install the truck had little or no power at WOT and I'm getting white smoke when shifting and little or no black smoke at all. There are no codes at the time, I did pump 15 gallons of diesel out of the tank when I added the FASS, put that back in and just added 10 gallons from a reliable station.
I'm not really sure if the issue started after adding the FASS or the AFE
