I hope you guys can help with this one. Two of my friends have 2000 3500s. Both have 354 gears. One is an auto and the other is a six speed 4X4. They both have had 275 RV injectors since they were practically new. The truck with the auto also has the VA box which works very well.
Today we took the VA box out because tomorrow the truck is going to the dealer for a problem in the rear end. Growling noises.
We then installed the VA box in the Six speed truck. Before I forget this box has been in this truck before. When we first got the VA box we tried it in a few different trucks. However when we installed it today and went for a test drive, it was pouring white smoke out the exaust. If you stop and Idle for a few seconds then take off, it would blow so much smoke out as you went through the gears that you could not see anything behind you. The truck ran very smooth and was making good power with the box however.
When we got back and parked the truck. A few minutes later we noticed several rather large puddles of oil underneath the front of the truck. The oil was comming from the drivers side of the engine, somewhere. Their was oil all over the fuel lines on the back of the pump and dripping everywhere. We unpluged the VA box and went for another test drive. The truck was back to normal. We went to the car wash and cleaned the engine, went home and checked for leaks. No leaks. This has us very puzzled. Any ideas? Thanks in advance.
Wayne
Wayne
