Archived white smoke
Archived amp meter
Archived Overflow Valve and Fuelline
i have a 95 with a problem, i put a banks kit in (turbo, twin intake, plate) i also put 370 injectors in it. know when you start it its blowing white smoke??? when it warms up it goes away for the most part. after warm when idling in park and you go to full throtle fast it breaks up and blows white smoke, if you accelerate slowly its fine. it also only gets about 10-12 lbs of boost in 1st threw 3rd but when it shifts to o/d the boost goes to 30lbs+ and close to 1200deg. thats when i let off even though it still wants to go! so what can i do to fix my problem?
Sounds like the timing may be retarded or possible overfueling. Also the spray pattern on the injectors may not be all that good.
Where is your timing on the fuel injection pump, need around 15 degrees advance BTDC.
i get a white start up (first 5-10 minutes) since i have turned my pump up and advanced my timing... . are you getting white smoke when the truck is idling say at a stop sign or lights?
timing has not been touched, it should be 15. i also think it is getting to much fuel. it runs better when at opperating temp. know that i put the stock plate back in. it seams to break up when boost pressure comes up with no load on engine.
some white smoke, when accelerating it starts out as a little black but then goes to white and will stumble if accelerated to fast like as if it is loading up on fuel. i took the boost anaroidline off and it ran better.
