Engine/Transmission (1998.5 - 2002) who has best price for map sensor?
Engine/Transmission (1998.5 - 2002) Stock TC
If you replace the MAP sensor on your own, do the codes reset themselves? Will the check engine light clear? How do you clear the codes? :confused:
I believe the check engine light will reset after 3 successful runs but the code remains and will need to be cleared with a scanner. That is the crank sensor code works.
Dave
