Who has the baddest 12 valve
Truck Modifications
AFC Housing Bolts
I have the BADDEST 12 valve in the TDR.
Oh, Im sorry, I thought this was a fuel mileage topic -10 to 12 mph consistently since day one. I think that gives me the title of baddest fuel mileage. Never, and I repeat, Never got over 400 miles out of a tank of fuel since the day I drove off the lot #ad
98 2500 4x4 QC auto "one of the last 12 valvers- late Dec 1997" 305 70 16, K&N ,260/608 torque plate,EGT and Boost gauge under ashtray. Bought a spray can of CAT-BE-GONE. Ring removed- Whats next folks????
I think Dave Mitchell would get my vote, although Autowurks' race truck is awesome too.
2001 3500 QC 4X4 black sport, ETH & everything else except 4. 10s Properly valved, improperly pumped.
6BT IN A GMC:
Like you, I would be interested in
those numbers too. However, I would
like to see "actual street driven
Dodges" be separated from "drag strip
only" trucks. (i. e. : trucks modified
placed in/on a trailer and towed to
the track)
Piers' old truck was near 450 H. P. and
over 1000 torque. He had e-mailed me
a few days ago about the exact #s and
at the moment I can't find it. I believe
Joe Donnelly is over 500 horespower at
this time. "My 6 Eats V-8's"(Adam) also
has high horespower/torque #'s as well
as "HVAC" and "DieselB59" (Chris). They
all definitely have me beat at 381 H. P. /
1069 Torque. My numbers came from the
"Mustang Dyno" at the "Scheid Diesel
Rally" in September of last year. Also,
at that rally last year "wwcd2" (Carl)
had dyno figures of: 384 H. P. /1036 Torque.
He achieved those numbers with the
following "upgrades" to the 24 Valve
auto: "Hot PE #3, DD I's and a "piggyback"
VA box.
In the latest issue of the TDR (Issue 31)
Scott Dalgleish did an article on "BD
Dyno Days" from last year. According to
his article the "top trucks recorded
450, 375 and 354 horespower with top
honors going to BD's Piers Harry. "
This was on page #54 of the magazine.
John_P
Red '96 4x4 2500 Auto 3. 54, TST #5, Major Pump Mods(By "Scheid Diesel") 370 Diamond B Injectors, Gov. Spring kit, AFC Spring kit, Banks Exhaust, Prime Loc, Cummins Chrome Kit,Psychotty Air Filter, Pro-Torque Converter, BD Valve Body, BD Pressure Loc, Isspro Gauges, Sendel 16" Alum Wheels w/ 33" BFGs
Auto Wurks Diesel's 3500 racer, "Project U-96". 6200 lbs. No nitrous, no propane, just #2 Diesel. 744 horsepower. 11. 5 seconds @ 114. 5 mph in the quarter mile.
Chris Timochko
AUTO WURKS DIESEL R&D TEAM
1997 5sp 4X4, Rhino Linings, Espar Heater, A. W. D. HX40 turbo, ATS 3pc Manifold, BD 4" Brake, Marine Compression, A. W. D. Custom Tuned Injection Pump, A. W. D. Intercooler, A. W. D. 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, A. W. D. Water Injection, NOS Diesel Kit, A. W. D. 6" Chrome Exhaust System, BD No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s.
Project U96 - 1996 3500 2WD racer. A. W. D. Marine Ultra Low Compression, A. W. D. Teflon-coated Pistons, A. W. D. High Lift Camshaft, Ported and Honed Cylinder Head, Intake and Exhaust manifold; A. W. D. HX40 Turbocharger, ATS 3pc Exhaust Manifold, A. W. D. Water Injection, A. W. D. Custom Fabricated Fuel System, Race Spec A. W. D. /BD P7100 Injection Pump, A. W. D. Custom High Flow Fuel Injection Nozzles, BD Auto transmission and Custom TC, Weld Draglites, Goodyear Eagle Drag Slicks, 5" Single Stack Through The Bed, Mag-Hytec on Rear and Transmission.
I saw that BPINE But it doesn't matter now cause I'm back from the dark side, never drove it so I didn't really move over, I got given the keys to a 2001 Dodge today & got told to go play and make some hp with a 24valve #ad
Now where to start #ad
Piers, Thats better but how do you get the stink off your hands before you eat dinner... LOL I'll bet HVAC is laughing his A$$ off right now.
EAT'M UP
97 2500 Club 4X4 3. 54, Forrest Green/Driftwood, LSD 5 speed, & Psychotty Air System, TST #11, 370 HP injectors, timing at 16 deg. , 16CM2 housing, AFC spring kit, Geno's Exhaust Blanket, TST EGT gauge & 0-60 boost gauge in A Pillar, Cat-be-gone, 4" Dynomax Bullet muffler, Crome 4" turn down, Rad fan removed, AmsOil Through out, Geno's trans filter kit, AmsOil Bypass system, Lund Winter front, Leer Cab Level Shell Driftwood , 255/85R16, Dyno'd 342 HP pre injectors & turbo housing *NRA/USPSA member and proud of it*
Piers,
I don't know you personally and I've never met you, but I seen that 'ol 12 valve can do.
Glad to see that you didn't have to waist too much time with that hard starting Powerjoke.
I have to say that Dave Mitchel probably has the "most" power of anyone I know of.
Lets see if I can get most of what I've "heard" of by more than one person.
Turns 5400 rpms during pulls,
around 800 becouse they have never been able to get a dyno to hold all they can make,
twin turbos at 85 psi boost
6000 rpm cam
head
monster pump
370 hp injectors with lazer cut nozzles.
and for the rest check out there web page, you'll see by that picture just how much fuel that thing is pumping.
It makes mine anemic at only
475hp and 1032 with #2 only
530hp and 1140 with lpg(with another 50 on the way, I'm putting Nowels system on it of which he's made 110hp on the dyno)
and 590hp with 1200 ftlbs
all of the #'s were at 24-2500 at the rear tires in 5th gear.
my truck has 3. 54 gears and 35x12. 50x16. 5 bfg's on for these runs.
More on the way here to, either the new Piers super injectors Joe is testing this week or maybe some extrude honed 370's or even a set from Enterprize, in any form more fuel. I'm also saving for a set of twins.
fyi Piers has made 520 on the dyno but he started breaking things. #ad
Adam,
You need to wander the crowds at the pulls!
What you heard is only half of what is said out there!
Here is a couple fresh ones;
Daves is over a thousand, right now, with one LARGE turbo.
He will have more turbos this year! How many?
My favorite? From the Ford crowd,
Any hot trucks here tonight?
"Few bad *SS chipped Powerstrokes..... but that Big White Dodge is gonna win, easy!"
I don't know what mine will Dyno, but I'll wager a case of beer it will be more than Johnboys! We'll find out at Muncie!
I have a good close up video of Mitchell building boost and coming out of the hole, who can post it?
Gene
1997 Cummins Dodge 4x4 Bombed & Amsoiled. Amsoil Premiere Direct Jobber, Member of: NRA Business Alliance, GLTDR, WANTED: Wrecked Dodges.
www.awdist.com
Hey Piers, cleverly planned. #ad
First you pretend to try out a drof so the loyal undervalved members will forgive you for coming back with too many valves under the hood #ad
Ok, I admit it, they really need your help. We cant let drofs stomp on those poor little overvalved Rams. I know you will be seeing Lawrence for some of those super mental injectors. Stage 6 anyone?
Hmmm, about four or five boxes hung on that very trying 44 pump, injectors like fire hose nozzles, 80 pounds of fuel pressure, dual HX55 turbos, head ported paper-thin, a veritable OCEAN of electrons. All to flex an automagic transmission. Go for it! #ad
Just be sure you have at least 500 hp at May Madness and several sets of tires #ad
My 6,
I'm sure you probably know this already, but your sled pulls at performancediesel.net are not viewable. Just thought I'd mention it.
2001 2500,QC,4x4,ETH/DEE,Dk. Garnet Red,Agate,E-Brake w/shifter switch, every option but leather.
Blair, do you really think you DESERVE #ad
a set of Super Mental Stage 6 DD injectors #ad
for the red Ram? That clutch you have and the wimpy ones you are thinking about won't even hold stock 370 injectors, even if they are the wrong part numbers from some bulk purchase, and come with the wrong washers #ad
You better spend more quality time with your Ram. It deserves better #ad
All right Piers I guess I will stop cursing Brian then. My I have the first dance at MM-01? Joe I heard you say the word DD does that mean I can install the Stage 6 injectors instead of the 370's? With Money comes HP and I am working double time.
Piers i guess we'll be seeing more of you in the overvalved forum soon #ad
... come on in , the waters fine , and MORE horseys is just the FLICK of a SWITCH away ... wwwwwwweeeeeeeeeee #ad
Okay Blair, you get the first dance... after I've had my 3 bottles of wine #ad
Joe I'm only gonna hang three boxes on the 01, why do I need lots of tires???I'll only need to beat you once #ad
John [Mopar Muscle] are you sure the waters fine over in the 24v forum??? I'm scared of sharks ya know #ad
John_P yep they are keeping the Ford, Christian was playing on the dyno the other night and broke thru the 600ft lb barrier #ad
