who is HP king?
I did not know!
14.0 "N" series Cummins
Powerjoke?
Dura-not?
Cummins?
What is the most HP made by all three?
What is the max boost that can be tolerated by all three?
Any links would be nice.
At Thunder in Muncie, this year, I was told that some of the pulling trucks were making 1300 HP. Don't know how true this is but, that's what I was told. Joe.
Matt,
I think Chris is talking about the following... . Himself (Ford F250 w/Scheid Engine), Terry Martin 98 Dodge dually (Scheid Engine), Kent Crowder (Scheid Engine), and I would venture to say that Haisley's "Rock Hard Ram" is right up there with them.
--Justin
Speaking of Rock Hard Ram, this weekend it blew 2 tires on the track (I suppose debris from truck or track).
That scared the crap out of me!!
It is a humbling feeling to see a truck running over 1000hp+, pulling a sled blow 2 tires less than 20 feet from you.
To further the conversation: Terry Martin's truck must have some sort of flat out wicked primary turbo. It sounds different than Kents truck, I guess you would have to hear it to believe (sounds like high pitched whine/scream).
Terry's truck used to be single charger with the Scheid built engine.
Now it is multiple charger, and runs right with Kent's, sometimes even better.
--Justin
It actually blew the rear, and the tires were so hooked into the track that the front end ripped the driver side knuckle clean out of the ball joints and then tore all the axle parts out. :--) Humbling definatly.
Travis
Damn, I'll have to call Van and give him my condolences. That sounds expensive. Makes me worry too as my truck is setup the same. Terry's truck has pretty much the same charger setup as the rest of us, just different plumbing.
