Who Is Using Twins?????
Overnight Stops Along I95
Looooong commercial trailers
Who is using twins on a daily driver and towing with them? Daily as in 186,000 on my 01. Would you do it again? Are they stable cant be down when im picking up a load for somthing that not everyone can work on or have the parts to fix. Usually have a chase truck that can hook to the trailer and take it but it is part of the escorts that it need to move the load. So if one is down we are still setting, which is not good we are on a time limit with the oversize loads that we pull.
I have PDR twins but havent towed anything large with them yet. my new TT has not been built yet.
I have 120hp injectors, powermax comp that's actually been tweaked a tad for a little quicker fueling down lower and PDR's HX40/HT3b setup. I'm told it should tow fine, a little laggy on the bottom but fine. I'm only draggin around 8. 5K though :D
as far as reliability you are not really working either turbo very hard and with this setup the ratio is nearly 1 to 1 around 40lbs of boost. the 40 is wastegated at about 40PSI so it should hold up to that.
you maybe could do the smaller 35 for your first turbo if you are worried about lag.
EGT's are great!
