Engine/Transmission (1998.5 - 2002) Who sells or can set up a matched set of injectors?
I have a fussy motor and need a set of flow matched injectors with the pop offs set at a certain level. Does anyone do this? I cannot use Formula 1 injectors as per Don, so I need recommendations other than the usual Mach series.
Thank you.
Pretty much any fuel shop with flow bench adapters for ISB nozzles can set them up that way.
Don probably feels his nozzles work the best at a specific pressure and doesn't want them ran any different. Just a guess... ...
So I am guessing that They would have to put the pump on the stand with the injectors and tweak the pump to get it even and then number the injectors so that they stay matched to the pump. (p7100).
pretty much any fuel shop should be able to do this. Just ask them if they can calibrate your injectors with your pump. We do it all the time for the stock stuff because it gives it a very smooth idle.
Tim
Most is true above. I use and sell Haisley's injectors and they come etched with a part number for a matched set, and on the card you recieve the pop off pressure is listed. Very smooth injector... ..... :D
I know Amianthus is running Buddha Power 8 x 11's in his 24v P-pump conversion, very smooth running truck also.
8 x 11 is large. I have a set of Scheid 6 x . 009's that i haven't put in because I know they will smoke alot.
