Archived who to rebuild turbo
Archived HELP !! Need a mechanic in socal
Archived 96 Loosing Prime
The B1-2 ex4 turbo on my 95 ram just went out. I need to have it rebuilt. Where should I sent it? I have well less than 3,000 miles on this turbo. My previous pdr hx40 went out prior to this one. It didn't have many miles on it either. I know the truck has bad rings but, that shouldn't cause turbo failures. The truck is rarely driven and I'm not happy.
Thanks for your help.
Jeff
Is the turbo getting enough oil? Drain problem?
How frequently do you run the engine? If it sits to long, you might want to pre lube the turbo, before starting.
Call Kenny Diaz @ Turbo Auto Diesel @ 602-272-5311. He's the one that built it and most other will charge more if they get their cut. He'll probably help you out since it has low miles.
Give chris a call @ River city turbo (501) 562-7488 first turbo he built was a 35/40 the new one is a htb62/14 all he does is turbos ;)
