Engine/Transmission (1994 - 1998) Whole bunch of questions
2nd Gen Non-Engine/Transmission high pitched noise
Engine/Transmission (1998.5 - 2002) does your exauhst brake work in O/D
This is all on a '94 6bta:
When you delete the automatic transmission cooler can, do you plug the coolant line holes or connect them together? One appears pressed in.
If you do not have an A/C compressor, what does the tensioner/alternator/lower hose mount look like? Does it use the 3 large bolts at the bottom like the one with A/C? Reason I asked is the mount is sitting right on a crossmember right now and will need to be altered or changed and the compressor moved.
Does the A/C compressor mount in other places for other 6bta applications while still running the serpentine belt? It will need to go higher.
I am going to be running real tight getting the radiator in front of the fan. Looks like 1 inch tops right now. I have never seen a Horton. Is it shorter? Right now it is looking like slimline electric fans.
Thanks in advance.
