Who's got the biggest?
Radiator flushing
Ol' Blue mo power
All right you guys settle down. Boost reading is what I need to know and how is you truck equipped. Whats "stock" reading and how do upgrades effect the boost.
Thanks
John
I'm not the biggest with only 22 lbs of boost. This is without touching the pump. Only mods so far are 16 cm2 turbo housing, K&N and a free flow exhaust. My Power Wagon injectors are on order. This is without an intercooler.
90 W250, 5-speed, isspro gauges, 16 cm2, K&N, Borgeson shaft
Currently running 22lbs also. I have turned the pump up, gone to a 16 cm2, 3" pipe all the way out with a DynoMax freeflow muffler somewhere in between. Injectors would be my next choice also, then I can turn pump back down to normal specs.
Scott
92 Ram, Bright White, Club Cab, LE package, 4x4, 130K, 3. 54 gears, Auto, Extra transmission Cooler under bed, 285x75x16 Cooper Discovery A/T, 16X10 American Racing rims, Tekonsha Brake Controller, Running boards, Lund Sunvisor, Marker lights, Lund bug deflector, Tonneau cover, Full cap, DynoMax muffler, 5" Chrome tip, 16 cm Turbo, Isspro Boost gauge, 23 lbs Boost, Pump Adjustments, Sprayed in Bed-liner, Rubber mat
'SHAKES, RATTLES & GOES'
Hey Deezul!
My '92 after a JRE inj. pump rebuild & enhancement, injectors & 3 1/2" exhaust will bend the needle to 30 PSI w/ the 12cm installed. I saw 31 PSI, Friday morning with cool dense air from our first blast of Fall here in the SE! My girlfriend's truck, similar JRE preperation, will get to 26-27 PSI with the 16cm at higher RPM.
No male induced testosterone embellishing required! True Story!
Before these mods with a wore out pump my truck couldn't even top 12 PSI. I use to have major "Boost Envy" from anyone that was in the 20 PSI range.
Keeno
1992 W250 5spd. 3. 54 gears, LSD, JRE enhanced VE Injector Pump, BD High Output Injectors, Banks "Stinger Plus" consisting of a replaced 12cm2 wastegated housing, 3 1/2" JRE modified exhaust/muffler, pyro/boost gages, K&N, Skyjacker 2 1/2" front suspension lift to clear 305/70R/16 Goodyear MT's, Mag-Hytec, Amsoil, Rhino liner, Fully Chrominated Aluminum Aftermarket Accessory T-handle Shift Knob
I am also low on the todem pole, I run about 23 -24 Psi with injectors, exhaust and some pump tweeking. The collar is still on the fuel screw, but the aneroid and fuel deliver pin have been the most adjusted.
Jason's Lil' Mack - 89 D250LE 2WD 5 Spd 3. 54 Reg Cab. K&N,"tweaked pump", BD Injectors, Banks Pyro/Boost, 3. 5" Exst tail section straight. 23 Psi boost.
E&M Custom seats. Bosch H4, PIAA 80W/80W HdLites. 100W Drv,55W Fogs.
232,500 miles (372,000 Kms) 7700 Hrs.
The Original Turbo Diesel
Hey John! How ya been buddy? Well, you saw my truck and rode in it. Since then, I've added a boost gauge and my 5" dual stacks! (and a few other things) I was getting about 27psi. Now, with those free-flowing 5" chromies, I get 30psi! I have the 12cm2 housing sitting beside me here because I haven't found time to put it on yet sooo... . Thats the stock turbo doin' all that good!(21 or 18. 5. . whatever) I will have to get a 40 or 50psi gauge when that 12 goes on!
Mine: '93 250 LE 4x4 5spd 4:10 Pwr win/loc/mir,cruise,dual 5" chrome stacks,12cm2 turbo,pyro/boost,diamond plate tool box, CB, 16x10" AR rims, 285/75/16 Bf goodrich, US Gear E-Brake,Fuller Roadranger shifter, PW injectors, K&N. "wirenut_21529" on Yahoo Messenger
Moms:'96 Ford B-Series school bus (5. 9 Cummins!)I'm gonna Bomb it!
Dads:'94 GMC 2500 6. 5L Turbo
Hi guys,I feel like I know most of you because I have been lurking on this site for almost a year, so I thought I would comment on the question. The boost on my 92 is 27 psi, the mods,have so far have been PW injectors, K&N, 16cm2 exhaust housing,no muffler, and pump adjustments
Stock I was at 13 psi. The 16cm housing gave 16 psi ($40/psi). The Banks stinger plus got boost to 18 psi ($500/psi). Diaphragm adjustment actually made the wastegate start working, it was set at 19-20 psi. When disconnected boost would hit 21 psi($0/psi). After the Power Wagon njectors and pump timing boost was 27 psi with wastegate disconnected ($70/psi). I then set wastegate at 25 psi where it is now. I have turned up fuel screw since but left wastegate alone. Boost comes up real fast to 25 psi, probably would peg needle if I disconnect wastegate.
'93 W350 Club Cab, Bright White, 5 sp. , 132K, Factory Options: LE, 4. 10 Limited Slip, 7600 lb. rear springs, tachometer, front stabilizer bar. Mods: Banks stinger plus, Linex bedliner, 25,000 lb gooseneck ball, 10,000 lb receiver, Tekonsha brake controller, POWER WAGON injectors-WAY faster than stock!.
Keeno; which place are you measuring: before, or after, the turbo?
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N air filter, cleaned-up exhaust, Dynomax straight-thru, rebuilt pump, 12cm wastegated turbo, thermostaticly controlled twin 14" electric fans, intercooler, modified 518 OD transmission, Gear vendors OD controler, R-134, louvered fenders, 93 aftermarket smoothe grille; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. Jesus saves!
Hey Jsimpson!
My 'boost' signal comes from the 1/8" NPT port on the intake manifold through a brass fitting. The Pyrometer is pre-turbo mounted in the exhaust manifold exit.
Keeno
UPDATE: Got the 12 on! Without the wastegate, I can get around 35psi! (assuming that my gauge reads accurately after it runs out of numbers, it might stop somewhere down there and I may be getting more) This doesn't sound safe to me so I designed a "special valve" for my wastegate will limit me to 32 psi max. With the wastegate hooked up without the "special valve", it is a trick to get it above 20psi. Don't ask about my "special valve", I would be embarrassed to tell how I did it!
Hey Burkey
Sounds like it oughta scream now, e mail me about that valve im curious. have fun and dont scare any Powerjokes off the road
96 SLT Laramie CC 5spd, 3. 54, no muff, no cat, 5"turn down tip
80gal fuel capacity. BD Brake, EGT,Boost + fuel pressure gauges. Member NRA/USPSA
I'm getting 26-27 lbs of boost right now in my truck. I expect to gain about 5-7 lbs with the installiation of my 12cm turbo housing here within the next few weeks.
91 4x4, 5 speed, 3. 55 gears, pw injectors, 16cm turbo housing, K&N air filter, "tweaked" pump, isspro boost and pyro gagues
