Whos got the Water/methanol kit installed
Flux 2 + 2 great shops= good times
engine addative
I was wondering about the Water/methanol kit and if it works to bring down temps towing uphill any comments and what type do you run?
I have had mine on for years, have six gallon jug in bed. Can't live without it. I like the Vari-Cool controller the best.
Rick
I have a 7 gallon tank under my truck's body, mounted outside the frame. I'm using a coolingmist.com controller and a Snow 220 psi pump with two large injectors in the air intake manifold. A mod I insist on having. It will not makeup for restrictions in airflow but certainly makes a difference. You can hear, feel, and see the difference.
Got it on a 4bt in a truck. Definitly makes a difference. And most definitly, get the coolingmist controller. 5gal/hr nozzle is a little small for my extra fuel so will install another nozzle soon. Would I do it again? Probly not, cuz it's too expensive.
The cooing mist controller has starting boost, duration, and ending boost. also has indicator light showing what is going on. Have nothing against Matt but I started with him when he drove a VW and sold on E-bay! Now well, what can I say. Being in the water purification business I put a inline filter in the injection line and a check valve so injection can only go one way and boost will not push back.
Rick
Rick
