FCA for '06,
Mopar part number:
5183245AA ($181. 80, dlr in NH)
Cummins part number:
4932457 ($95, Cummins Northeast)
I feel for you guys in Canada...
$177. 35 at Cummins, Eastern Canada
Mopar might be hard to find in stock AND avail. at dealers.
He found several dealers that had exactly one, which probably means they are being ordered against a work order/repair.
If you call a Cummins Distributor they can have any part that is in stock in the Memphis warehouse overnighted for 15% extra.
Extremely reliable and the Dist. can order parts from Memphis until late in the evening.
Works great if you call "ahead" on your route.
Links to the Cummins Distributor lists:
http://www.cumminspower.com/na/locator/us/
http://www.cumminspower.com/na/locator/canada/
More to follow, including the possibility that the FCA can/could dump enough fuel to make you think you've lost your lift pump.
I can get 20psi to the suction line by running both pumps (stock in-tank + Carter/BD in-line) with the engine OFF.
... but it goes to zero as soon as I START the engine.
Takes about a minute to get a gallon thru the h2o drain w/engine running.
Nothing wrong with the pumps.
Filter only has about 1K miles on it and I'm out of new ones.
I'd give anything for those return flow test fittings right about now.
This trip has been a total meltdown...
