My apologies to SFrey (sorry Scot). I believe I answered his question about the source, or at least one source, of that hood, but it seems the thread has turned to better headlights, a never-ending quest for us early 2nd gen owners.
There is another company out of Texas that sells a very similar hood on ebay for at least $200 less. The snorkels are spaced wider and it doesn't look quite as aggressive and cool, but pretty close.
eBay Motors: 94-01 Dodge Ram Air Hood Hemi Style Hood (item 170133083051 end time Sep-18-07 22:12:10 PDT)
The flying deer that launched himself into my lap put several dents in my hood and I plan to replace it with one of those. My search for such a hood is how I knew where to link you. If this one in your photo were cheaper, I would buy it instead. Of course, looks aren't everything and its a roll of the dice for fit and finish when dealing with fiberglass or aftermarket sheetmetal parts. If anyone buys one of these hoods, please let the rest of know how it fit.
As for the headlights, I never considered the one-piece housings would lack adjustability. That is a serious problem and I'm glad to have been informed. It too bad, really. I like those lights.
My harness and relays for the headlights finally arrived on their slow boat from china, and those very same headlights were about to be ordered. My headlight switch (#3 for me now) can't take even one more meltdown, or at least the pigtail connector can't. It is badly deformed and charred and barely plugs into the new switch.
My headlight situation is really aggravated by the snowplow light system, which routes all of the juice back into the cab to a DPDT toggle switch and then all the way back out to the headlights again to change from plow lights to truck lights. Way too much juice being sent too far through too much undersized wiring, which is the Dodge's problem to begin with. The relay harness will solve that. New, clear lights will solve the hazing problem of the stock ones.
I have no idea how Dodge wired the headlight relay in the underhood power distribution box, but it should NOT be sending all of the juice for the headlights, tailights, marker lights, trailer lights, etc. through the factory switch and undersized wiring like it does. I have met two different guys whose Dodges burned to the ground from dash fires caused by that headlight switch and wiring.
I guess I will have to start over and look for "sport" headlights if I want to be able to solve the lighting problem. Sounds expensive... If anyone can point the way to a reasonable cost source, I would appreciate it.
Scott
