A few thoughts on the Legendary Cummins durability
There are a whole bunch of reasons why a diesel runs so long compared to a gasser. There are other reasons why a Cummins is even better than a regular diesel. I am going to repeat some things others have said just to keep my thoughts orderly.
Why diesels last so long:
1) lower RPM range. Engine stress increases with the square of rpm, so doubling rpm from 2K to 4K means FOUR times as much engine stress.
2) They HAVE to be built stronger. Remember when GM tried to put diesels in passcars that were just converted gassers? All kinds of probs-- they just weren't tough enough. For the most part, diesels are designed to operate under conditions that would melt a gasser. 16:1 compression or higher? Onlya few race motors are built to that level in gasserland, and they don't have a turbo increasing cylinder pressure even more!
3) yes, diesel oil burning has a slight lubricating effect (as far as I know) but not much. It definitely helps upper cylinder lubrication
4) diesel fuel burns slower than gasoline does under pressure. This means that the pistons sees less of a hammer blow-- it's more like a steady push. This is relative to designed load. A diesel sees overall a LOT more pressure on the piston. This means that overall the internals have to be much stronger, which means heavier too. That's why diesels rev slower, as if they have a 100 lb flywheel.
5) mechanical simplicity. others have covered this.
6) tougher materials. this is related to #2. You will see extra beefy FORGED steel cranks, tougher piston rings made out of nodular iron and such.
7) A typical diesel has a lot more oil in the crankcase which helps component temperatures among other things. I would think that is would tend to make the whole engine run at a more even temp (less the turbo)
Specifically the Cummins:
1) fewer parts being inline 6
2) 7 bearings for those 6 cylinders, instead of a 8 cylinders on 5 bearings like v8. See the PSD vs CTD thread in the 3 Gen forum for more on this.
3) I am pretty sure that the Cummins NAME alone is worth about an extra 200K miles
Overall, it's just STRONGER. . sorry I can't really explain it better.
Feel free to correct any erroneous info. I fancy myself a gearhead extraordinaire, but I am pretty new to diesels, and have been wrong once or twice before
Hohn
