run cold for quit some time and then turn warm. Like today it was 90 plus and it runs cold but not for very long... maybe 20 min. Then it turns to the ambient temperature. However tonight on my way home it would run you out of the cab. I have had this problem for 4-5 years..... it seems the AC works when I really don't need it. I have had it recharged, but not from an ac shop. I went to an independent shop and they said they will charge $180 to evaluate and determine if I have a leak, and what needs to be repaired. Could this be a leak when it works well at times? What do you think needs to be fixed? Can an independent do this or should you go to an ac specialist..... I might also add that everybody who sees my truck always says that they have never seen one drip so much water from the passenger side... . I have looked at the service manual... . what a nightmare to check.....
