Lift Pump pressure spike control - Protect your guages
RustyJC said:
..... In 3 years I've probably gone through 1 pre-filter senders and 6 or more post-filter senders - the pressure spikes from the VP-44 seem to knock the post-filter senders out... ... ... .
Rusty
There is a super cheap, easy way to cure those spikes.
All you need is six feet of RUBBER fuel hose. Don't get the stuff with braided exterior because that will defeat the purpose.
My mechanical fuel pressure guage when mounted on the post filter orfice would swing from 8-9 lbs up to about 20 lbs. That obviously will destroy any guage in a hurry.
I am now using the rubber hose to put the guage inside the cab and to snub out the pulsations. If you don't want it inside the cab, just coil it up and zip tie it loosely to the firewall area.
2nd part of the trick is do NOT bleed off the air in the hose. That is part of your pulsation damper.
Works like a charm, no needle fluctions what-so-ever. I now get a true average effective fuel pressure from my stock Cummins lift pump which is still on the engine block.
15-16 lbs at idle
10-12 lbs at 70 mph cruise
08-10 lbs at heavy throttle (2500 rpm accelerating thru gears)
As long as I see a postive pressure greater than 7-8 pounds I am not going to make any changes. If it ain't broke, don't fix it.
I do have a reserve pump plumbed in at the tank, so I won't have to get out in the rain or sweltering heat to change a fuel pump WHEN it does finally go to lift pump heaven.
