DPuckett. .
Yes,they are a tad smoky if your maxed out at full fuel and will haze at time like that,again,if the tune is good they can be made to be very drivable. With right foot moderation any injector will not be too smoky. I have seen some EDM's that when as to roll actually wisp unburnt fuel into the air and throw as much or more coal than a 370. Remember,when there is no smoke in the chimney there is no fire in the oven.
Eric_B...
IF you already had the other stock injector cores and wanted to try that then,I guess it would be a way for you to do it. Remember the 30-45% increase you quote for those tips would have you fall into the 280-300 hp range and you would be short 70hp on the 370's and unless you had someone who could flow and pop test the injector after the tip was installed I wouldn't trust them. To get close to the 370's in HP you would need the big tips set and just buying them you would have way more money than 370's in just tips,let alone if you didn't have the injectors and had to buy them.
My point in all of this is the 370's have now,with the coming of the EDM injector,all of a sudden gotten a bad rap. They were in some of the most lethal 12v's in the country for years making outstanding power. Sure they smoke. but,add a 10 plate to a later 12v 5spd truck and even a 215 injector will roll coal. Again,my point is the tune up,not all the smoke problems these guys whine about is the injector,its their tune. Heck even EDMs will have at idle so that tells you no injector is perfect so you need to find what fits your need and tune your setup accordingly. Now as for bang for your buck,find a EDM injector that gives you the HP capabilities the 370's do for the same cost and your on to something,I don't think you can... ... ... Andy
