I had noticed the day I bought my truck that it had a oil leak. It goes from the oil filler, down the timing cover/case, down the oil pan, back from the oil pan along the oil pan bolts to the bellhousing area. Also the remote oil filter lines are oily and dirty. I figured at that time it was just a normal used truck leak and that I would just have to change some seals or gaskets in the future. I recently ( months ago) pressure washed the timing case off, or tried to, and the stuff seems not thick but very coherent or stuck to the metal. Now when you get down to the oil pan it isn't so dirty, more of a wet liquid film. Also the oil lines are caked with dirty oil. I've checked the rubber to metal connections on the oil filter lines and they don't seem to be leaking. What's funny is it starts way up at the oil filler and goes way to the back of the oil pan. Plus somehow gets on the oil lines. Could this be multiple problems or just one leak spreading. I wouldn't think it would be the KDP beacuse why would there have been a oil way up by the oil filler. Although, the KDP has never been addressed. I'm on the regional list I think for the jig. I sprayed that top part of the timing cover off and it hasn't gotten oily since, in that area. You wouldn't think someone spilled a bunch of oil while adding oil on a oil change would you? Any ideas would be great.
Thanks,
Trever
Thanks,
Trever
