2nd Gen Non-Engine/Transmission wierd vibration
I have a strange vibration coming from the from of my truck. I can feel the vibration with my left foot to the left of the brake pedal all the way up forward on the floor. When I turn on level ground I do not get the vibration, when I go over bumps straight I do not get the vibration. But if I hit a bump in the middle of a turn I get this vibration. The vibration is more noticeable in the morning then in the afternoon. Any ideas as to what is causing this vibration would be appreciated.
Maybe wheel bearing or ball joints. Try jacking the truck up off the ground and see if you have ball joint movment or if the wheel bearings feel rough.
Is it a rotational vibration or static vibration? Could have something to do with your hydroboost, P/S? Your hydraulic lines are right there.
the vibration seems to be more static, it feels like someone is taking a hammer and hitting the floorboard of the truck under my foot.
