Have a bit of a unique problem with the WIF light. Light is on steady. Disconnected the sensor - light is still on. Disconnected the next connector upstream - the one that picks up the lead from the intake air sensor. Light goes out. Ah I thinks - WIF lead is grounded in the bundle. Open bundle, don't see anything obvious and since I'm on the road I just leave the connector unplugged. Get on the road and no speedo or odometer - distance sensor ground goes to engine block through disconnected connector as I soon figure out. Get home and put meter on all wires in bundle - no shorts and 0 resistance to ground on all black wires (gnds). Next, follow wiring further upstream - pop that open - same symptoms - WIF goes out. Do same checks for shorts - no joy. Look at wiring diagram - should be 12V coming from message center light to connector - not there - however, with key on there's a very weak voltage on the side of the connector that goes to the ECM. So does this sound like I'm going to have to replace the ECM? Has anyone seen this before?
Thanks,
Mike
Thanks,
Mike
