Does the Max flow kit eliminate the stock lift pump, in favor of a auxillary pump? And if not can you easily eliminate the lift pump and put a pump back by the tank and still use the filter up front, or add a pusher pump settup to the existing pump?Fixing to buy one if it is going to fit my plans, a buddy has a list of An fittings to retrofit the stock fuel system, and delete the stock lift pump in favor of a Holly Black set up, they may work as good for my needs. Hope I'm not being confusing
Thanks Jared
Thanks Jared
