Details here: TDR Privileges
Yeah, I found a post stating your size was tight. Assuming you have AT, Tirerack says that is 34. 5" diameter. Toyo site says Toyo is 34. 8". Think that . 3 will do me in?
I have 245/70 19. 5 Toyo's with SuperHitch. Had to remove all of the air out of the spare to make it fit. The SuperHitch makes it a tight fit. Pacbrake Ebrake gives me onboard air.
Yes... with a stock exhaust and stock rear differential cover. Some aftermarket exhausts and a PML or Mag Hytec rear differential cover will change that. I have a 35" Toyo MT in the spare well location and it is a tight fit. It barely clears the diff cover and the exhuast. Plus, secure the spare tire with a cable lock as you are probably exceeding the weight rating of that little winch (I don't trust it and as soon as you start to crank that big 35" tire up with it, you will see what I mean).
Will a 315 size tire on stock rim fit there with a Mag Hytec? Thinking about getting Mag Hytec for the rear, but sounds like it may not fit with my 315 spare.
