I just finished installing a 16 psi Westach fuel pressure gauge on my bone stock fuel system, 112K on original lift pump. Truck has always run great. I have read that 16psi is desired at idle and around 10psi on WOT. I drilled and tapped the banjo bolt on the bottom of the fuel filter housing, ran it through an 18" grease whip to the sender, no leaks. Bled the system by removing the valve in the banjo at the VP44 and cycling once. LOTS of fuel came out! Put the valve back in and started the truck after maybe 8 seconds cranking and read 6psi at idle:--) My filter needed to be changed real soon so I did, now I get 5psi at idle and ONE psi WOT
First, this is BAD, right? Second, did I screw up something? It was a very simple hookup. Will air in the grease whip cause a very(?) low reading? Oh, the lift pump now sounds very sickly. It used to have a very solid "moan" when I cycled the starter. Now, (just tonight) it sounds inconsistent and not nearly as solid as it did. Did I kill it by "priming" the way that I did? I "happened" to have bought a spare lift pump last Friday, I'm guessing that I need a new one for whatever reason. . I have not driven the truck but it idles fine and goes to 3400rpm if I stand on the pedal. . Any and all input welcomed. Thanks.
