Will an '08 speed sensor function correctly in an older dana 70?
Rear slide window leak
Ball Joints
Long story ...
The sensor bolts right in place.
The AAM teeth the sensor uses are square.
The Dana 70 teeth are rounded.
Will the sensor work in the 70?
Since they operate on the same principle, I would guess they would... however, the profile would affect the type of signal the ECM sees, so it might not like it.
