Good advice
Hi Mark, Wasilla Rod gave good advice.
The radiator drain is on the drivers side lower inside corner of the radiator, using a pair of pliers, grab the flat tab of the drain and turn counter clockwise while pulling out on the tab. The plug will rotate and come out at the same time, it only backs out 1 or 1 1/2 turns. Catch the antifreeze to keep your pets from getting into it. It is poison to pets. Just drain about a gallon or two, to drop the coolant level below the top radiator hose, so that when you remove the hose you don't make a mess. Remove thw upper hose to get it out of the way of the fan shroud and fan.
Just use a long punch or chisel to knock on the fan nut to loosen and afterwards retighten the fan nut. The fan nut threads are left hand threads!! So you have to hit the nut in the direction you would to tighten a normal thread. Then carefully spin the whole fan assembly off. set the fan in the bottom of the fan shroud
Remove the washer bottle, and the four 10mm bolts holding the shroud to the radiator, and remove the fan and shroud together. It helps to have an extra set of hands to do this. You can have the shroud loose and ready to remove before the fan if you want. You can shove the shroud back toward the engine and pull the fan out the gap between the shroud and radiator, just be careful and don't mess up the radiator fins.
Then just start taking the items off that are in the way of the front cover. The crank damper bolts will come loose with a long ratchet or breaker bar, just kind of 'jerk the bar' they will come off. They are 15mm. Tighten the same way.
Plan on reusing the gasket and seal, they rarely must be replaced if you are carefull and patient when removing the cover.
I wish you were nearby, so I could help. These are 'home workshop' methods, I use an air chisel with a blunt drift for the fan, and have a barring tool to hold the engine for the damper bolts, but the above directions work fine.
Read all te FAQ's about the KDP, then jump in and get your hands dirty!!
Hope this helps, Greg L
