Will Hummer H2 Wheels work on a 2004 2wd??
Strange vibration..
Gauges
Curious if the Hummer H2 wheels will work on a 2004 2wd?? I think the wheel pattern is the same (8x6. 5"), but I'm not sure if the width and offset will work.
From what I can tell the Hummer wheels are 17x8. 5" and +18mm / 5. 5" rear spacing.
Also, what maz size tire can I run on a 2wd??
Thanks!
I have them on my 2003' 2 wheel drive... sorry no updated pics yet. But I do like them and have gotten alot of good comments. They do stick out a little because of the offset, & I have the 315's which were on the hummer. In order to make them work with that size tire, I had to put a 1 1/2" lift in the front. If I buy new tires, I will go a little smaller than the 315's, I think 285's would be better.
i am running hummer tires on my 04. 5 2WD 3500 and they rub a bit, but nothing to worry about. just dont turn FULL lock.
th ewheels will fit, just stick out a tad more than factory. they still need amchined.
Grant
Here are some updated pics of my truck, a 2 whl drive with a 1. 5" lift on the front, with the hummer wheels & 315 tires:
here are a few with the stock wheels and tires, with no front end lift:
Hummer Wheel Machining Shop?
Can anyone recommend a shop to machine the centers of Hummer wheels to fit my Dodge? I am looking for something near Riverside, CA or in the East Bay of the SF Bay Area.
Just acquired 5 brand new Hummer takeoffs, wheels w tires, caps, 32 lug nuts. Got to love all those people in LA who want huge rims and low aspect tires to run around on the freeways!
Thanks in advance.
Thanks in advance.
Not real close to Riverside, but this may help others. I got mine done in Ventura, at Quality Machine Shop on Ventura Ave. They honed out the middle and cut down the ram caps. The only part I did was tin snip the tabs. btw: the hummer caps won't work.
might as well sell the lug nuts off to someone who owns a gm. . they are M14x1. 5 while ours are 9/16-18. not compatable. the stock dodge lug nuts will work on the H2 wheels
