Engine/Transmission (1998.5 - 2002) Will HX-40 Be Big Enough?
I'm looking to up grade injectors to mach 4's or 5's but I was wondering if the HX-40 would be enough to cool EGT's and flow enough air. With my set up right now would the Jr HX-55 be good? Even with the DD3's? Both of the turbos are in my price range, thats why I'm asking. Thanks yall
Eric
How cool do you want your EGT's to be? You can always adjust down your fueling when you are not trying to run someone down and then the 40 would be fine. On "kill" :) I don't think the 40 will keep you under 1300 degrees.
