Details here: TDR Privileges
Came to a stop light, when it turned green would not start out in first gear, and no over drive. Codes p 0477, and p o700 what sencers need to be replaced ? BD trans with about 3500 hundred miles on it. 03 3500 drw's
l would likw to thank you all ! found the prouble, l just had new battiers and cables installed and a lift pump. louse ground cable and broken wire, also found where they had broken the vacum line for cruise control. Everything is back to working like it is supose to.
