will not start
Hey I need A 03 Cummins Automatic Transmission
Fuel Rail PRV leaking...is it supposed too??
I have an 03 dodge 1 ton. Thougt the problem was a bad injector, too much bypass casues it not to start. The fuel gague was at a 1/4 of a tank. I brough the fuel level up to 1/2 a tank and it starts just fine and runs great. Is this a problem with the lift pump? Does any one else have a similar problem?
The fuel pick up snaps into a socket in the bottom of the fuel level sending unit. They sometimes com loose and rise up from the bottom of the tank. You must pull the sending unit to check.
Bad lift pump might cause it too. Still on my original, but I have a spare Holley replacement pump under the seat.
(moving this into the 3rd gen engine forum instead of cab & chassis)
