Will oil temp probe obstruct oil flow in oil filter pad?
hey look what I found cheap
where found diesel performance shop in Quebec
PBerry
I have a isspro trans temp gauge and sender and want to install it for oil temp instead as I have a 6 speed. The probe extends 5/8 deep after installed in filter pad port. Will this obstruct oil flow and cause a problem. Anyone that is for sure on this a reply would be appreciated. Thanks in advance
I wouldn't hesitate to put the probe in the filter head. The probe extends 5/8", but the filter head casting is at least 1/4", so that means only 3/8" penetration in the flow.
No big deal. I haven't done it (yet), but I know others have.
Ryan
Ryan
you mean 3/4"?
No, I meant 3/8". I mean the threads are roughly 1/4" deep, so the probe will actually stick into the flow (5/8)-(1/4)=3/8. Right? Or have I missed something dumb?
Ryan
Not sure of the thread on the filter head but you can get an "extender" from Diesel Manor (can't seems to find it on their page anymore... . hmmm). It's a coupling with a nipple to space the sending unit about 1/2" further out. I bought one with my cooler line for the isspro sending unit and don't need it. It was expensive ($16 IIRC).
It's not a real good idea to space the sender out from the filter head body. I did this, and I don't get accurate temperature readings.
Ryan
