Will turning the smoke screw in cause the coolant temperature to raise in the truck? How about the starwheel? I know it will raise EGT's but how about the coolant temp. My truck has started running hotter than normal when towing a trailer. It is not in the overheat range, but it is towards the high end of normal range and I don't like that. It started this winter, so had my radiator flushed and installed a new non cycling thermostat. But it still gets warm like before I did that. My pump is not turned up that much and I am running a open air filter, so I know I am getting good air flow in. My next thing to do was replace the radiator. Do you all have any suggestions on what to try. Maybe backing the smoke screw and starwheel back out some? O, by the way when it gets warm, I can let of the go peddle and it will start to fall back down fairly quickly.
Thanks, Bill
Thanks, Bill
