my plans are to run twin turbos (hx-35 , B2), and a amsoil by-pass filter (BMK-11). will the stock oil pump beable to suppley the needed extra oil to run am extra turbo and a bypass filter. the by-pass filter will be returning the oil to the oil pan. also how am i goting to plum this, i only have to oil ports advailavle to suppley oil to 3 things. one sugestion that someone has made it hook the smaller turbo and the bypass filter up to a t fitting attech it to the first oil port and hook and attach the larger turbo to the second oil port. is the stock oil pump even capable of delivering enough oil? also will having a tubo and a bypass filter hooked up to a a t fitting being supplyed oil from a singel oil port provide enough oil? Makeing sure that my engen it getting enough clean oil it my top piority. i dont want to run the amsoil dual remore system becaust iv herad that i reduces the oil pressure and does not fulter at well as the a stock size filter with a bypass filter. iv tryed looking up this imformation, but iv hit nothing but dead ends.
