will these fit?
Pro Comp Xtreme Mud Terrains
Tow mirror repair
I currently have a 3" front leveling kit. I was wondering if these tires will fit with no rubbing issues. They are Toyo A/T 325/65/18 (35x13x18. ) Also, are toto's a better tire than the BFG A/T ko's which will come in 305/65/18's? Just wanting some pros and cons between the two.
Chris
Depends how wide and the backspacing on those 18" wheels. If they are no wider than 9" wide and roughly 5. 5"-6" of BS. You will be ok. You may get a little rubbing on your control arms w/ sharp turning (tight parking space turning, etc. . ), but no big deal.
I have the 325/17's Toyo's on my stocker wheels w/ my suspension in my sig that has 3" up front and no problems.
You will rub the back bottom of the front fender well when turning the wheel w/ that BS.
You can grind down the corner so they will clear, but that is your call.
Thanks for the heads up. I will keep an eye out for that. I have a friend who has an '02 dodge with the same rims and has 325/60/18 tires and doesn't rub. Wonder why mine would but his doesn't.
