will they fit???
Guages, guages, guages!
Seafoam Auto-marine Motor Treatment
DB,
It depends on the offset of the wheel. Most aftermarket wheel do not have enough and will rub on the wheelwell(not good). Get yourself a set of OE aluminums (8inches wide w/the correct offset) and they will work very well. You might get a little rub on the lower control arm when you are at full turn but it doesn't hurt anything. FYI you need at least 5. 75 inches of offset to work properly.
Hope this helps
DD
A leveling kit would clear the 295's just fine. Im running 305's on the stock rims with NO suspension changes whatsoever and do not rub!
