Will TSTPMCR work from a 05 on my 03???
boost question w/ tst
low fuel pressure
I was wondering if a TSTPMCR off of a 2005 dodge ram would work on my 2003 ctd. If not can I send it in to tst to have it reprogramed to work??? Thanks Wes :)
I'd contact TST to find out for sure. Does the 03 HO have the electronic wastegate? I know the 05 does. My 03 SO came with a new boost elbow for the wastegate.
Someone else should know for sure.
Randy
All 03's have mechanical waste gates. I agree with Randy, call TST ~ they may even be able to load different s/w to make it work.
Scotty
I think you would have to buy the boost elbow to turn up the boost. "These units work on the new 04. 5/05 Ram 325 hp/600 torque and they appear to work very well. The wastegate setup is different with the 325/600 engine and it takes a few more minutes to connect than with the 03 and 04 engine. " From the TST site
No need to call unless you want to know which program is in the box. What is the Serial Number?
2003-2005 trucks all used the same exact TST model. Only difference was the 2004. 5-2005 trucks came with a different type of boost elbow that required running boost tubing to the intake manifold.
2006 and 2007 trucks use the exact same box and timing harness, but require a different injection harness as the 06-07 trucks went to a 2 plug design from the older 3 plug design.
