I have a '08 Ram 5500 w/ 152,000 mi and no fault codes. My turbo seems to lag and makes noise as if being bogged down. I removed turbo and disassembled for inspection.
Slider ring and actuator were clean and operated smoothly. I reassembled and still get periodic turbo noise with low power/economy. Dealer did full system diagnostic and said all engine parameters were functioning within specs. I removed turbo again and this time noticed approx 1/32" radial play on impeller shaft. The impeller tries to stick when turning and applying lateral pressure on shaft.
This can't be a good thing and I'd imagine this explains the noise. If this occurs during spool-up and has been causing low boost, wouldn't the turbo speed sensor and boost sensor see as a fault?
I'm gonna take a gamble and ordered a new turbo which arrives Wednesday 4/21/10.
Any input from you all would be greatly appreciated!
