Have been thinking of a way to mount a winch without breaking the bank. I really like the buckstop bumpers and/or the warn winch mounting setups but don't want to spend a couple grand just to mount a winch.
On our 3rd gens... where the tow hooks/rings mount there are 4 bolts to hold each of them on. This obviously has to ba a strong point or a tow hook could not mount here.
If these were removed and a mount was fabricated using bar stock... say the same stuff used to make a hitch... could a mount of sufficient strength be made to hold say the 15 or 16K winch? yes... I know it could be made strong enough... but would the mounting points here be adequate? Also... d-ring or tow hook mounts could be built into the winch mount.
I was thinking a 3rd brace could be added directly in the middle and run down under the bumper and have its own cross member built in. Now obviously it's hard to understand what I mean exactly without being able to have a picture of it here... so don't immediately say it won;t work... it's an idea and I'm looking for other ideas to go with it.
I know this sounds a lot like a 'front hitch' and it is to a degree... but with a winch mount instead of (or in addition to) the hitch. And no I'm not looking into one of those receiver winch mounts. I want the winch on there... not sliding around the bed of the truck.
The steel needed to do this would cost MUCH less than buying a $1000+ bumper setup and I can do a fair bit of the fabrication myself. Plus the end result should weigh significantly less than having a full bumper added on.
I'll see if I can't draw up something and scan it into my computer.
