The infamous "wind seal" noise has been brought up several times in this forum. The noise is driving me crazy (as if I wasn't already), especially with pop-up loaded and in crosswinds. Dealer says they can't (or won't) do anything. In this forum previous threads advising how to loosen and re-adjust hinges have been met with mixed results. Some other past suggestions were to push in foam caulking backer rod try injecting foam or other media into the interior of the door seals (they are hollow). What I want to know has anyone tried to "stuff" the door seals with anything and has that worked? What did you use to fill door seal up with?
My seals are NOT torn, part of the reason why dealer refuses to replace per the TSB.
Thanks All
Thanks All
